#601 Post autor: Pszczyna »
PRZÓD
ZESTAW, TARCZE, 280 X 25 MM,
HAMULEC PRZEDNI, WENTYLOWANE (JNS - STOSOWAĆ 93197592 / 5 69 066) (NR PRODUKCYJNY 90539466)
Kod OEM: 569060
FEBI BILSTEIN 17211
ATE 24.0125-0131
ATE 24.0325-0131/ATE
TRW DF4048/LUC
KAMOKA 1032082/KAM
KRAFT AUTOMOTIVE 6041660
REMSA 6584 10
CIFAM 800-514C/CIF
ZIMMERMANN 430.1483.52/ZIM
ZIMMERMANN 430.1483.20/ZIM
A.B.S. 16953
JPN 30H9030-JPN
BREMBO 09.7629.10/BRE
BREMBO 09.7629.75/BRE
BREMBO 09.7629.1X/BRE
DENCKERMANN B130079/DEC
DELPHI BG3405/DEL
BLUE PRINT ADW194312/BLP
TOPRAN 205 524/TOP
BOSCH 0986478883/BOS
MAXGEAR 19-0804MAX
MEYLE 6155216017
TEXTAR 98200-0919 PRO
-------ZESTAW INSTALACYJNY, TARCZE I klocki CIERNE HAMULCÓW Kod OEM: 1515001
ZIMMERMANN 640.4201.00/ZIM ------550,00 zł
KOMPLET, OKŁADZINY CIERNE, HAMULEC, BEZ AZBESTU Kod OEM: 1605035
TRW GDB1350/LUC----KAMOKA JQ1013280----KAMOKA JQ1012590----PROFI POWER HAMULCE 1B1020/PPH---A.B.S. 37076---VALEO VAL301454---DENCKERMANN B110251---METELLI 22-0539-0----FEBI BILSTEIN 16232---DELPHI LP1309---BOSCH 0986424457---BREMBO P59045---TOMEX BRAKES 1300---TEXTAR 23832-19,6----TRW GDB1350D--- ATE 13.0460-7116---ZIMMERMANN 23057.195.1---ZIMMERMANN 23057.995
TYŁ
ZESTAW INSTALACYJNY, TARCZE I PŁYTKI CIERNE HAMULCÓW (MOCOWANIE NA 5 ŚRUB)
Kod OEM: 1515065
ZESTAW, TARCZA HAMULCA TYLNEGO, 264 X 10 MM (MOCOWANIE NA 5 ŚRUB) (JNS - STOSOWAĆ 95526658) (NR PRODUKCYJNY 90575113)
Kod OEM: 569109
ZESTAW, OKŁADZINY HAMULCOWE CIERNE, TARCZY HAMULCA TYLNEGO (JNS - STOSOWAĆ 93188727 / 16 05 122)
Kod OEM: 1605086
rafaellowarszaw
Auto: Opel Zafira A 1.8 NJOY
#602 Post autor: rafaellowarszaw »
Dziękuję za poprzednie nr części
Proszę jeszcze o nr. Części ( Sonda Lambda przed katalizatorem)
W0L0TGF7542049582
Z góry dziękuję
Rafał
#603 Post autor: Pszczyna »
CZUJNIK TLENU, KATALIZATOR (POZYCJA 1)
----------------------Kod OEM: 855356
BOSCH 0 258 003 307
BOSCH 0 258 005 650
BOSCH F00HL00394 401,00 zł
CHRYSLER 56041213AB
MAZDA AJ5718861A
JAGUAR CAE1105
FORD F75F9G444AA
MAZDA JE4818861A9U
MAZDA KLL618861C
MAZDA ZZM718861
DENSO DOX-1566
DENSO DOX-1569 213,00 zł
DENSO DOX-0119 126,00 zł
BEHR HELLA SERVICE 6PA 009 166-501
NTK 1867
MAXGEAR 59-0074 125,00 zł
DELPHI ES20281-12B1 159,00 zł
VDO A2C59513327Z 360,00 zł
ESEN SKV 09SKV904/SKV 134,00 zł
HELLA 6PA 009 166-501 177,00 zł
ESEN SKV 09SKV909/SKV 139,00 zł
MEAT & DORIA 81565E 157,00 zł
MAGNETI MARELLI OSM032 142,00 zł
VALEO 368456 245,00 zł
AUTOMEGA 0855356/DLO 121,00 zł
FACET 1.997.342 202,00 zł
TOPRAN 206 193 172,00 zł
ESEN SKV 09SKV682 196,00 zł
ESEN SKV 09SKV053 161,00 zł
CALORSTAT BY VERNET LS140069 187,00 zł
FAE 77247 243,00 zł
ERA 570076A 179,00 zł
MEAT & DORIA 81022E/MAD
PIERBURG 7.05271.55.0 420,00 zł
FEBI BILSTEIN 36806 219,00 zł
FEBI BILSTEIN 175881 187,00 zł
------------------------9202575 GENERAL MOTORS
VAG 030906265BH
FORD 1R3A9G444D2A
NISSAN 226A01S707
SIDAT 90054
FORD 98AB9F472BB
FORD F09F9F472C
FORD F3UZ9F472C
FORD F85Z9G444DA
MAZDA FS1G18861
LUCAS ELECTRICAL LEB243
PROTON MD183145
JP GROUP 880855356
rafaellowarszaw
#604 Post autor: rafaellowarszaw »
Pszczyna pisze: 04 mar 2024, 14:38 PRZÓD
Kod OEM: 569060
FEBI BILSTEIN 17211
ATE 24.0125-0131
TRW DF4048/LUC
KAMOKA 1032082/KAM
REMSA 6584 10
CIFAM 800-514C/CIF
A.B.S. 16953
JPN 30H9030-JPN
DELPHI BG3405/DEL
TOPRAN 205 524/TOP
MAXGEAR 19-0804MAX
MEYLE 6155216017
TYŁ
Kod OEM: 1515065
Kod OEM: 569109
Kod OEM: 1605086
Proszę o informację czy takie tarcze i klocki na tył bedą pasować ( bo w spisie z VIN nie ma nr. Producenta tylko ogólny OEM
https://allegro.pl/oferta/tarcze-i-kloc ... 4758443630
VIN W0L0TGF7542049582
rafaellowarszaw
#605 Post autor: rafaellowarszaw »
Z góry wielkie dzięki
Rafał
#606 Post autor: Pszczyna »
rafaellowarszaw pisze: 06 mar 2024, 13:42
Kod OEM: 569109
Kod OEM: 1605086
Nie warto przejrzeć całego opisu oferty ALLEGRO :czerwona: :lis: :lis: patrz zdjęcie , reasumując tak to zestaw do twego auta :witam:
rafaellowarszaw
#607 Post autor: rafaellowarszaw »
Fakt nie doczytałem. Skupiłem się na powierzchownym poczytania i tym głównym symbolu...😋
zafira3city
Auto: Zafira A 1,8 125PS
Oznaczenie silnika: X18XE
#608 Post autor: zafira3city »
Pszczyna pisze: 10 lut 2024, 13:21 POMPA WSPOMAGANIA UKŁADU KIEROWNICZEGO, ZESP., WYMIENNY(-A, -E), KIEROWNICA PO LEWEJ (POWRÓT RDZENIA NR 95524457)
Kod OEM: 5948127
TRW JER100/TRW---1484,00 zł 1416,00 zł
DRI 719520337 1128,00 zł
DRI 719520337/DRI 1371,00 zł
Czy to możliwe aby była niezgodność części po nr vin ?
Nie miałem szybciej czasu sprawdzić ale okazało się że mam pompę 9127416
czy jest możliwe, czy ktoś po prostu taką podmienił ?
Ostatnio zmieniony 08 mar 2024, 14:37 przez Pszczyna, łącznie zmieniany 1 raz.
Powód: Poprawiłem literówki
rafaellowarszaw
#609 Post autor: rafaellowarszaw »
Witam ponownie
Mogę jeszcze poprosić o numer części : pasek wielorowkowy
VIN. W0L0TGF7542049582
Z góry dziękuję
Rafał
#610 Post autor: Pszczyna »
zafira3city pisze: 08 mar 2024, 11:36 Czy to możliwe aby była niezgodność części po nr vin ?
-----mam pompę 9127416 ale ona jest zamienna z 5948127 :zły:
Numery katalogowe zamienników13105726, 24405522, 24436412, 9226482, JER100
Numer katalogowy oryginału 09127416, 09127417, 09156545, 09156546, 09191977, 0948003, 13105726, 24405522, 26065105, 5948001, 5948127, 9226482, 9226483, 93188235, 93188236, 948015, JER100
Wspomaganie kierownicy Opel Astra G (98-05), Zafira A (99-06) dla producenta: TRW
Motorherza: G3010
SILNIKI OGÓLNE0948003, 5948128, 9226482, 948012, 09156546, 24436412, 09127416, 5948001, 9226483, 948015, 09191977, 26065105, 09156545, 5948009, 93188235, 13105726, 09191975, 5948127, 93188236, 09127417, 24405522
GM---26065105, 5948009, 9156546, 93188235, 13105726, 9127416, 5948127, 9191977, 93188236, 24405522, 9156545, 5948128, 9226482, 948012, 24436412, 9191975, 5948001, 9127417, 9226483, 948015
ATG--EPR0010AT
ZAUFER413N10018Z
#611 Post autor: Pszczyna »
rafaellowarszaw pisze: 08 mar 2024, 12:31 Mogę jeszcze poprosić o numer części : pasek wielorowkowy
----------PASEK NAPĘDU, ALTERNATOR (DLA STOSOWANIA Z ALTERNATOREM 120 A) (OPRÓCZ VAUXHALL'A) (NIE UŻYWANE Z POJAZEEM LIFTOWANYM) (JNS - STOSOWAĆ 93181316 / 63 40 626)
Kod OEM: 1340658
OPEL
09117585; 09117586; 09194660; 09194661; 1340016; 1340054; 1340635; 1340658; 55562418; 6340626; 6340627; 90573798; 9117585; 9128952; 9194660; 9224370; 93169491; 93181316; 93181317; 93182266
GATES 5PK1210
DAYCO 5PK1210
SKF VKMV 5PK1212
FEBI BILSTEIN 2886
KAMOKA 7015050
rafaellowarszaw
#612 Post autor: rafaellowarszaw »
Można prosić o nr. katalogowy do katalizatora
(Nie wiem czy te informacje będą potrzebne ale w razie co podaję
Opel Zafira A 1.8 125km 92 kw prod 10/2003 ( wersja po liftingu))
VIN: W0L0TGF7542049582
Ostatnio zmieniony 21 mar 2024, 10:20 przez Pszczyna, łącznie zmieniany 1 raz.
#613 Post autor: Pszczyna »
Nie ciekawie to wygląda z uwagi iż katalizator jest zintegrowany z kolektorem.
KOLEKTOR, WYDECHOWY, Z KATALIZATOREM (JNS - STOSOWAĆ 13106942 58 49 005) (POWRÓT RDZENIA NR 9117104 ----95 08 030)
Kod OEM: 849178
KOLEKTOR, WYDECHOWY, Z KATALIZATOREM (JNS - STOSOWAĆ 55555948 58 49 015) (POWRÓT RDZENIA NR 9117104 ----95 08 030)
Kod OEM: 5849005
KOLEKTOR, WYDECHOWY, Z KATALIZATOREM, NOWY WYMIENNY (IDENT EB) (POWRÓT RDZENIA NR 9117104----95 08 030) (OPRÓCZ VAUXHALL'A) (JNS - STOSOWAĆ 95507207 8 50 215)
Kod OEM: 5849015
USZCZELKA, KOLEKTOR WYDECHOWY DO GŁOWICY CYLINDRÓW
Kod OEM: 5850640
Katalizator WALKER 20854 1964,00 zł
Katalizator KAMOKA 8015074 777,00 zł
Uszczelka kolektora wydechowego VICTOR REINZ 71-34282-00 = 22,00 zł
Uszczelka kolektora wydechowego VICTOR REINZ 70-34282-00 = 22,00 zł
Uszczelka kolektora wydechowego ELRING 447.560 =19,00 zł
Uszczelka kolektora wydechowego BGA MG8576 = 8,00 zł
Uszczelka kolektora wydechowego CORTECO 026636P = 33,00 zł
Uszczelka kolektora wydechowego AJUSA 13183300 = 23,00 zł
Uszczelka, rura wylotowa WALKER 80563-21 = 34,00 zł
Uszczelka kolektora wydechowego GLASER X81064-01 = 32,00 zł
Zestaw uszczelek kolektora wydechowego FAI AUTOPARTS EM874 =19,00 zł
Uszczelka kolektora wydechowego TOPRAN 206 180 = 20,00 zł
Uszczelka kolektora wydechowego TOPRAN 206 180 =19,00 zł
Uszczelka kolektora wydechowego TOPRAN 5850640 = 19,00 zł
Uszczelka kolektora wydechowego FA1 412007 = 27,00 zł
rafaellowarszaw
#614 Post autor: rafaellowarszaw »
Czyli taki katalizator z kolektorem chyba odpada....
https://allegro.pl/oferta/opel-zafira-a ... 2277986221
#615 Post autor: Pszczyna »
Kod silnika: Z18XE
Tutaj niby są do --- XE --- https://sklep.exhaust.pl/product/katali ... _MQAvD_BwE
lecz Zafiry A brak podejrzewam iż tylko wystarczy zmienić kąt złącza do łącznika elastycznego
Zadzwoń do firmy BOSAL i skonsultuj się z nimi.
Wróć do „Podwozie”
